amg55driver
Maryland
Ahhhh got cha! Thanks for the screenshot! So even with 7F, with all original figures like your screenshot, the raptor DRL should be same as factory setting.. correct?
I will play around and will get back to ya’ll.
cao0215
driver is installed, everything is fine, but i can not connect to my 17 raptor, always said unable to connect to vehicle. please make sure the ignition key is on and try again, anyone can give me a hand?
amg55driver
Maryland
Happened to me couple times.. my module is cheap out of date one, only wifi so i had to unplug and plug back in etc, that worked for me.. good luck!
amg55driver
Maryland
wow.. thanks to you all, got all my original values from Ford's site!!
726-26-01 0101 0000 0056
726-26-02 0000 0000 0055
726-45-01 0A00 1101 0190
726-50-01 108E
so I basically just disabled DRL nothing else.. haha
amg55driver
Maryland
OK! so I got the Parking light DRL enabled thanks to many of you guys!
Though, I want to do Lincoln style mirror auto fold, the DDM is not available...
I can not find it under anywhere.. am I missing something? I ordered the correct OBD2 wire (OHP ELMconfig) from the Livnitup's suggestion (the USB one not Bluetooth one)..
https://www.amazon.com/gp/product/B01F0GVBWY/?tag=fordraptorforum-20
Antho
Looks like there is a HS and MS can switch on your adapter. You need to flip it to see all of the other modules on the other Canbus. Some modules are on MS and some are on HS. So your're only seeing one.
jhsocal
Here's a link to the video from the Doc showing them program the auto fold mirrors. Hope this helps.
Nickshu
Northern Colorado, USA
Hey guys I made a mistake programming...then realized I forgot to backup the PDM before starting. Can someone who has a 2019 Raptor with 802a look up your stock coding for line 741-05-01 in the PDM module?
I think it's 1A00 68 but I am not certain.
Sorry to be a PITA, Thanks in advance.
