DrewFish11
I know this is old... Is there a way to change the specified number to , let's say 42 or 38? If so, what code do you use, BCM or IPC?
Thanks
If you’re referring to the specified tire pressure in the cluster here is what you change. You can google what psi you want and convert it to hex. 25 psi is as low as mine would show. Anything lower and it would just come up as two dashes under “specified”.
