gto19
Yes. Couldn’t get whole pic. Second line down in both photos.
Thanks
We might be thinking two different things . Are you talking about disabling the double honk when the engine is running ? I’m talking about getting rid of the honk when I press the lock button more then once on my key fob .
Wfo
Syracuse
Thanks
Gotcha
bfr
Mountain West
With forscan is there a way to eliminate the honk after you press the lock button on the key fob twice ?
Do you know how to use the Edit, Find and Replace function in Google Docs. Type “honk”. The main FORScan spreadsheet for the F150....Common sheet...line 111. That should work whether it is factory or aftermarket remote start.
bfr
Mountain West
Lines 110 & 111:
Remote Start - Aftermarket enable
BCM 726-22-02 xxx1 xxxx xxxx
BCM 726-38-02 xxx0 xxxx xxxx <-- optional, disables horn honk with 2 presses of lock button on fob
icecoldak
Could you tell me which deal to switch . I’ve used forscan for the exhaust and double honk so I kinda know what I’m doing now ..:)
Thanks
What is the exhaust Mod--Forscan?? never heard of that one
gto19
Lines 110 & 111:
Thanks!
Would I just adjust line 2 of what your showing me ?
