Shaggy
Administrator
Staff member
Admin
Arizona
**** you!
I have helped more people than you have. I help people every time. My beef with the haters has nothing to do with you. They asked for it and I gave it to them. Now u get the hell out of this bitch!
You need to chill out with the name calling! I have been seeing more posts like this by you. Just giving you a warning here.
BIGDJE
OC, CALI
turned off fake engine nose lost my android audio looking at the sheet it says use 0 which is wrong that turns off front tweeters usb also it should be 9 just turn off fake engine noise anyone else run into this?
kromealt
Did you try 9 and sound any different? I tried 0 on my 2019 and still had fake engine noise but only under WOT - I ended up going back to default. Note, 0 worked fine on my 2018 I may have to give 9 a try.
BIGDJE
OC, CALI
was messing with forscan for so long my truck shutdown on low battery protection mode
i need to go charge it or drive it and try 9 but that makes sense since 0 will turn off USB hence no android auto since that has to be plugged into usb port
Fender
Ive done the lincoln mirror fold, double honk, global windows, secure idle, heated cooled seats on screen. Initially done the auto start stop function, but i read a lot of threads about this altering the battery charging system so i switched it back!
Any info on this? And yeh i read the f150 and forscan forums.
Olsen185
Has anyone been successful with the global window open/ close on a 2018? This is the only change that I can’t get to work. If it makes a difference I have a 2018 with 802a package.
