This may help the DIY'ers with lubing the cables. https://www.amazon.com/dp/B0012TYX9W/?tag=fordraptorforum-20
When I tried injecting lube into the cable housing using just the standard wd40 straw, all I got a was a mess. I'm sure some lubricant gets into the housing but a syringe and needle works much better.This may help the DIY'ers with lubing the cables. https://www.amazon.com/dp/B0012TYX9W/?tag=fordraptorforum-20
Mine is in today for the second time getting this fixed. Mine wont close on the passenger side and it wont open on the driver side - go figure lol
Either way i hope this is the last of this issue for me. They are claiming it was related to a faulty door handle on the passenger side issue so that is getting replaced. The driver side just started acting up so we will see what they say there.
My truck vin is not part of the tsb and ford doesn’t have a solution. Wtf. Should have kept my gen1!!!!I have a late production 18 with the metal oil pan, my passenger door has been the only one to freeze. It has done this a bunch of times. Not feeling good about the dealer opening up the door panel and putting it back together correctly. Shouldn’t the late production 18s have this update during assembly?
My truck has all of the latch updates and still froze.Had mine fixed 2 weeks ago during a cold spell of around 18 degrees. Driver side rear door once opened wouldn't shut and after it warmed up a bit in the afternoon it finally latched. Dealer said it takes over a day to complete the fix (they do all 4 doors like someone else mentioned.) I've now tested all 4 doors down to single digits with no issues after the repair.
