ford raptor oem fox shocks coil options?
C
circafwsk8r
Flint MI
why wouldn't i they came one every raptor ford produced. im just not sure if i have them the right way?
---------- Post added at 09:07 PM ---------- Previous post was at 09:06 PM ----------
anyone post a pic how they go, or explain to best of your ability. lol
---------- Post added at 09:09 PM ---------- Previous post was at 09:07 PM ----------
what i don't understand is that my top strut mount is at the same angle so im essentially make it back level again with the spacer, witch makes my top strut mount at a dif angle than the shock body. maybe this is correct but im not sure.
nohel
In my truck
I wish i remembered from when i changed mine out so i could help you. they are there because the raptor shocks are at more of an angle because of the longer control arms and where the shocks mount on them. Also with how your truck rides are the shocks you got at bottom perch or have they been moved?
C
circafwsk8r
Flint MI
i moved them to mid perch. just found some pics and the fat part of the wedge is facing toward the tire on the top of the strut mount. i believe i have them backwards. im going to have to change them. should help as well.
Wilson
South Dakota
SS lines from SDHQ
http://api.viglink.com/api/click?fo... Raptor&txt=&jsonp=vglnk_jsonp_13785903337718
did you ride in it with them set at bottom perch first?
I think that is what you should do if not see if it help's the pic looks like your front end is up just a tad anyhow. if that doesn't help just cut off a bit of the spring. if all else fails buy some new one's.
---------- Post added at 04:48 PM ---------- Previous post was at 04:45 PM ----------
SDHQ Offroad - Brake Lines
C
circafwsk8r
Flint MI
Thanks Wilson. Actually I had a heavy ass welding table in my bed at the time of the pic. The front is 1" lower than the rear normally. Also I have the oem wedge spacers backwards gonna try to fix that today after work
C
circafwsk8r
Flint MI
So I put the oem spacers back to how I believe they go and the ride is way worse than before. Idk why and I'm tempted to put them back how I had them. Fat part of the wedge facing the tire. It pretty much squares up the top strut mount level this way and rode way better. Has anyone put both spacers between the coil over and mount? Idk what to do at this point I'm pretty sure I have them the right way but now the ride is terrible compared to before.
SDHQJASON
Gilbert, Arizona
If you are wanting custom coil springs to change the spring rate, I would look into calling deaver and giving them the part number off a stock raptor coil spring. With this info they will have everything they need from the dimensions to the stock spring rate. Then they can go back and modify it to your liking. We have done it on race trucks before to get it dialed in.
