Raptor911
So I have been meaning to do a writeup for a long time now so here it is:
I purchased a Magnetic Drain Plug from DRAINPLUGMAGNETS.COM and have been using it for 1500 miles with no issues. See below for details and pics.
When you order you get one plug with 3 aluminum crush washers. You also get a gauge in which you can measure the stock plug against the plug you received to make sure proper fitment. I can tell you that the magnetic plug I received was identical to the stock plug with 3 exceptions:
- the stock plug has a bigger washer(head) when compared to the magnetic plug
- the magnetic plug does not have that extra piece at the end which serves no purpose whatsoever in the stock plug. If you were to cut off the end of the stock plug then it would be the same length as the magnetic plug
- The socket head is smaller on the magnetic plug which would lead you to think that the bolt size is different BUT IT IS NOT. I hope this makes sense.
A raptor takes this size >> m14x1.5x16 >> just click on the link and do a control-F (find) m14x1.5x16.
BTW .. the magnet is super strong. When I tried to screw it on I had a difficult time as the magnet kept wanting to get sucked in the pan instead of going straight into the hole. I can totally see someone trying to install this plug quick and because of the magnetism it will cross thread because it was not straight in the hole. You have been warned!
I have more to add but I just have too much work right now. So I will come back and edit this.
