Ford Performance Oil Filter Gen 2
Frank N
NJ and Outerbanks
I use the same FL500 that came from the factory just for the piece of mind that if my motor ever blows under warranty, it will be one less reason to deny a claim.
1BAD454SSv2
HELL I ZONA
Ford Racing CM-6731-FL820 Oil Filter
Measurements
* Filter Weight - 19.75 oz
* Can OD - 3.68" / Seam OD - 3.76"
* Overall Height - 3.99"
* Can Material - 0.019" thick steel
* Filter Element OD - 3.44" (at element)
* Filter Element Height - 2.81"
* Media - Cellulose - Synthetic Mix? Oiled? (appears orange)
* Number of pleats - 63 + 1 joint
* Depth of pleats - 0.73"
* Media length (unrolled) - 100" (seam crimped)
* Media width (glue not included) - 2.50"
* Media thickness - 0.029"
* Total media surface area - 250 sq. in.
* Total media volume - 7.25 cu. in.
* Inner Filter Support Material - 0.010" Thick Perforated Steel
* Inner Filter Support OD - 1.71"
* Indentifying marks
Can - 810050516 / Made in USA
Bar Code - 7_56122_07567_8
Label - 6945234
Base - 22 / MM
* Gasket Retention - Multiple Crimps
* Thread - M22-1.5
* Relief Valve Location - base end
* ADBV Material - Silicon
Motorcraft FL-820S
Measurements
* Filter Weight - 13.1 oz
* Overall OD - 3.76" @ seam / 3.66 @ can
* Overall Height - 4.05"
* Can Material - 0.02" thick steel
* Filter Element OD - 3.25"
* Filter Element Height - 2.51"
* Media - Cellulose (appears pink/orange)
* Number of pleats - 43 + 1 joint
* Depth of pleats - 0.68"
* Media length (unrolled) - 65.5"
* Media width (glue not included) - 2.375"
* Media thickness - 0.035"
* Total media surface area - 156 sq. in.
* Total media volume - 5.4 cu. in.
* Inner Filter Support Material - 0.012" Thick Perforated Steel
* Inner Filter Support OD - 1.68"
Can - Made in USA
ADBV - 6944453 / AAX / 150
* Thread - M22-1.5
* ADBV Material - Silicone (orange)
K&N HP-2010 Filter
Measurements
* Filter Weight - 16.8 oz
* Overall OD - 3.66"
* Overall Height - 4.09" to top of "nut" / 3.71" to top of can
* Filter Element OD - 3.36"
* Filter Element Height - 2.24"
* Media - Synthetic (appears pink/orange)
* Number of pleats - 55 + 1 joint
* Depth of pleats - 0.72"
* Media length (unrolled) - 89.3"
* Media width (glue not included) - 2.1"
* Media thickness - 0.030"
* Total media surface area - 187 sq. in.
* Total media volume - 5.6 cu. in.
* Inner Filter Support Material - 0.015" Thick Perforated Steel
* Inner Filter Support OD - 1.66"
Can - 072206C1 / Product of USA
ADBV - AAX / 77
Base - ZZ
* Gasket Retention - Press Fit
* Thread - M22 -1.5
* Relief Valve Location - dome end
* Gasket includes lubricant
Nate_Climb
Utah
Measurements
Label - 6945234
Base - 22 / MM
* Thread - M22-1.5
Motorcraft FL-820S
Measurements
Can - Made in USA
* Thread - M22-1.5
K&N HP-2010 Filter
Measurements
ADBV - AAX / 77
Base - ZZ
* Thread - M22 -1.5
May I ask why you chose to use the Wix?
