GEN 2 Flowmaster FlowFX Review
Toadster
Toadster
Folsom, CA
Similar to the FOMOCO touring sound.
It’s a love/hate situation.
There are times when I wish I didn’t hear the exhaust inside the cabin. Particularly in the lower RPM range.
On the highway, I’m guessing you’ll hear the exhaust buzzing behind you ever so slightly too. Not drone... but an exhaust note.
That’s the case with my FOMOCO touring. Similar with the Flowmaster?
Looking back.... overall... 3
Different exhausts.... stock was the best overall in terms of balance between tone, volume and daily driver friendliness. I’ll be interested to see what you think of it in 3-6 months when the novelty has worn off.
I’ve been debating welding in some twister 3 inch resonators to see if I can muzzle mine without having to go back to the huge heavy stock system.
can you post a vid of your setup?
Gsteve
the eb exhaust is the rosy odonnell of exhausts. You can change it but it will never be any good.
Well if that’s true then you sure picked the wrong analogy.
Because if you replace Rosie O’Donnell, your replacement will surely be better.
well... ok, i can think of a few worse, but not many.
anyway, the point remains - poor analogy.
Jake17
★ REBEL LIFE ★
Toadster
Toadster
Folsom, CA
CRAP finish doesn't clean well/prone to flaking
I went raw brushed satin w/Scotch-Brite[emoji769] fine
That’s nifty - use 0000 steel wool maybe??
Nice thing is with the Flowmaster it keeps the stock geometry so I could swap the tailpipes in the future if I want to [emoji41]
Jake17
★ REBEL LIFE ★
60 grit to remove paint > finish w/Scotch-Brite
Wipe down with SS cleaner/polish
Gsteve
i said change , not replace , as in hair and make up.
