First Oil Change...TIP!
Madcowranch
Genetically Modified
OK
I pay 19.99 for 5 quarts of Mobil 1 on sale at WalMart. I think I'll stick with that.
If you want to learn more about oil than you ever cared to, spend some time over at bobistheoilguy.com.
Madcowranch
OK
But you need the Extended one which they do not carry.
I need 6 and a 1/4 quarts when I do mine.
Not unless you're doing 15K change intervals. M1 EP does contain a bit more cleaning agents than regular M1. Both surpassed all retail brand synthetics in deposit control. Uoa's don't show any meaningful difference between Mobil 1 and EP. If they're the same price, I'd go with the EP, otherwise no need to spend more.
MTF
Celebration, Florida
If your only doing 5 quarts you're not getting all the oil out!
And M1 EX has other additions like something equal to Prolong or Slick 50
Same thing the Ford blend has.
Madcowranch
OK
Same thing the Fled blend has.
I was just using the 5 quart as a price reference point. That's the size jugs it comes in. I know our trucks hold more.
The EP just has more of the SuperSyn additive.
Since I'm doing 5K OCI's, I don't think it would benefit me from what I've read.
Chris@FreedomMotorsports
FRF Gofur
Woodlawn, Virginia
From what the service manager told me about someone's case
When it comes to oil and warranty, you need the special blend that Ford uses or the full extended synthetic like Mobil 1 has.
Ford uses these formulas to increase MPG numbers and longevity.
Your service manager is spinning a yarn. There is absolutely no truth at all in Ford requiring a certain brand oil for warranty purposes. UNLESS they are providing it under a service plan where they provide the oil for free. Unless they are doing that, it is illegal for them to void the warranty because you don't use the brand they recommend.
As for requiring a synthetic blend, etc. As long as the oil you are using is the correct weight then they cannot void the warranty unless they actually PROVE that the oil failure caused an internal engine failure. A synthetic blend is not going to provide the best mpg. Only a full synthetic will do that.
All that being said. Mobile, RP, AMSOIL, etc are ALL good quality oils. Deciding which one to run depends on your own personal wants and needs according to how you want to manage your maintenance schedules. People who use AMSOIL for extended intervals of up to 25K miles and in some cases more than that on one oil change will see the same results as someone who is running Mobile EP for 10-15K miles except for one difference. The person running the AMSOIL for the extended interval is going to spend less money annually on their maintenance.
Now, I NEVER recommend anyone make the change to AMSOIL, RP, Mobile or any other brand and extend their intervals in blind faith. YES, AMSOIL Guarantee's their oil (when used with their EA filters) for up to 25K miles or one year under NORMAL driving conditions and 15K miles or one year under Severe Duty driving conditions. However, every vehicle, person, driving condition, climate, etc, etc, etc is different and as a result some engines are harder on oil than others. I highly recommend that anyone that wants to extend intervals at all, do so by utilizing used oil analysis to allow a lab to determine your intervals. Doing so will help you head off possible problems, let you know whether the oil is holding up, whether it is full of contaminants, etc. Those customers of mine that use AMSOIL (I also sell RP, Champion and others) and utilize UOA still spend less annually.
I also agree, bobstheoilguy is a great informative website. But there is as much if not more opinion based assumptions there as there are on any other website.
MTF
I hear ya, just sharing the water cooler talk.
I do my own oil changes too.
But, A synthetic blend is not going to provide the best mpg. Only a full synthetic will do that.
This Is not what Ford is promoting. I think it even says something in our manuals about that.
FRF Gofur
Woodlawn, Virginia
Yeah, if you look up the "Moss Magnuson" act. It makes it illegal for manufacturers to void warranties due to customers not using the brand of oil they recommend unless they provide said oil for free. This is why so many manufacturers are doing just that of late and some have been doing it for years.
tracyropem
Taking my truck in for first oil change tell dealer I'm bringing my own Mobil1 they tell me that could void my warranty bad thing is I'm a Mobil dealer
