GEN 2 First oil analysis
JohnyPython
Canada
Just checked my first UOA on my Raptor. Was less than .5%. Lab reports says less than 2%
Also checked my STi with about 90k on the motor. It’s the same.
Did you collect the sample on a hot oil? So as to burn off any water/fuel.
You might want to get a second opinion as in try another lab.
Keep us posted.
MnFlyer
MnFlyer
MN
Keep us posted.
Not sure, i had my mechanic get the sample when he did my oil change.
It may have sat and was relatively cool when he changed it, but I can’t say for sure.
Ill give blackstone a try with the next oil change.
JohnyPython
Canada
I’ve only used Blackstone so I can’t speak about other labs.
I give my vehicle a good run before I change the oil. Get the oil up to operating temp so it flows better. Also get it circulated through the system in hopes that I get most of the dirty oil out.
My understanding is that you sample the oil from the mid point of the drain.
Also, use a good quality filter. Motorcraft FL-500, Wix etc.
Hope you get better results next time so you can rest easy.
