MTF
Well, it takes about 300 miles to complete a full transmission learning cycle unless you do the battery reset.
It's about 50 miles for the Fuel Trim cycle.
Interesting, I’m about or a little above the 300 mile benchmark since disconnecting the PC.Well, it takes about 300 miles to complete a full transmission learning cycle unless you do the battery reset.
curious would a sct update or tune "fix" the leadframe the same way the ford recall would? meaning any programming the dealership does would just be overwritten by the tuner?I was thinking you may have been part of the Transmission leadframe FSA, but that was only for 2011-2013 models.
Have you checked your transmission fluid? Ford published an SSM a while back relating to “abnormal transmission operation” caused by the radiator cracking and causing coolant to contaminate the transmission fluid. Your truck is within the build date range.
Well, truck goes to dealership tomorrow. Went into limp mode with wrench on screen. Got to side of road, shut off truck, let sit a few min and then restarted. I was able to get home. It doesn’t look like my VIN falls into Lead Frame recall, next to check my warranty coverage before Ford tells me it’s 100% on me, which I’m prepared for. Once this is figured out and fixed, time to look at a proper tune.
