GM3SF
- Joined
- Oct 27, 2012
- Posts
- 189
- Reaction score
- 224
Nah, it’s wider but not so much wider that it’s really been an issue.
---------- Post added at 12:16 AM ---------- Previous post was at 12:10 AM ----------
Not at all man. I get it and obviously you do too. This was a one off job. Sure if someone handed over what they wanted fabben and they were just duplicating it, yeah then maybe it would be quick. But not this. Not when you’re going back and forth, templating stuff, tac welding and checking for fit, then doing it again, literally starting from scratch on the other side of the truck because the shock is now in front of the axel instead of behind it like it was on the other side. Again, not that simple.
---------- Post added at 12:17 AM ---------- Previous post was at 12:16 AM ----------
Thanks a lot. As you can see we put our truck through it’s paces.
Very interesting idea...using a removable air shock...if keeping the rear end up is for you then, this looks like a good way to go..
My present truck (have a 2018 Raptor on order) is a 2wd Titan set up for DD and prerunning. The rear end has a Deaver mini pak, custom shock mounts, 2.25 SAW piggy backs with a custom tune and a very custom air bump setup. Running about 11" travel out back with about 7" of compression travel...my last tow was a enclosed trailer just at 5000 lbs, and with out weight dist bars the back end dropped 2.25". Don't care about the "droopy" rear end, but man does it ride nice and hit some really big dips on the I15 to Vegas getting into my bumps but never felt it...
My background includes a lot of race car fabrication, my specialty being TIG welding cages and aluminum...and run into the guys who think my quotes are way over priced because they have a MIG welder in their garage...and anybody with a tube bender can make a cage...Yeah right...
Sorry for the long post...
Not into camping and towing, but I really enjoyed your instagram page. Also great job by your fabricator to get a solution that looks factory. As a mechanical engineer and self professed "better mousetrap" guy I can appreciate the amount of time and ability it takes to provide solutions outside the box.
Great job.
