yyep, usual spot. works best for range andthe led lights up a lot at night
bout time slacker
What model/features?
white/orange is ignition. + when key is on -when key is off. 7 pin plug on the left side of the steering column. you will need a 5.5mm socket to remove the 3 bolts in steering wheel shroud. black plug. there are 3 or 4 white/orange wires in thr big harness so be very careful in making sure you got the right one. you will also possibly need a resistor if the led does not have it. so connect the ignition wire to the CATHODE SIDE of the led (-side) and connect a constant power to the ANODE side (+)
