BlueSVT
Hey Blue, what are you typically airing your wild peaks down to when you go off roading?
I always go to 25 psi... And recommend the same for almost any tire. Unless we're in soft sand, then we go as low as 15-16 psi.
25 gives it a much smoother ride, less prone to puncture or slash on rocks, but still maintains good sidewall stiffness for high speeds and sliding without popping a bead.
