Factory aux lights
JURASIK18
SoCal
The nice thing is that the wiring is already there to use your Aux 1 for some brighter fogs.
I put all 4 fogs on Aux 1 and i have the factory fog switch on the headlight knob empty for now.
Syberspace
Pittsburgh
I swapped out the internals of the factory DOT SR-M to a pro driving SR-M. MUCH better. I only did the inner ones on AUX1. The internals are pretty much a direct swap and if you know how to solder, pretty easy. I wanted to keep the factory housing and adjustment capability.
Also, if you adjust the factory lights up higher (mine were pointed at the ground mostly) this help a little.
The factory fogs are lacking in output for sure.
swoop1156
USA
I went with the triple Rigid Scene Radiance lights. They look great and I enjoy the backlight, but they're definitely not a real driving light. Light gets blasted everywhere which is usable, though I'll prolly swap out at some point in the future with a driving beam of sorts.
