barneys raptor
I have a 2019 raptor with 43k miles on it. Always had issues with burning excessive oil. First clue was low oil pressure warnings followed by limp mode (weak throttle response). Dealer checked it out and told me there’s no rhyme or reason, these trucks just burn through oil. Now I know to put 2 quarts in every 4-6 weeks and haven’t had a problem since with the low oil pressure. I am now having issues with weak throttle, check engine light comes and goes but no other warnings. This issue started while getting up to speed on an on-ramp. I was at about 25-30% acceleration and lost all juice in the throttle. I laid off the gas, got back on it and had some power back but weak throttle issues started. Some days it has weak throttle throughout the drive, some days it starts normal then half way through the ride you lose normal throttle. Truck has a hard sputter at idle on occasion since this weak throttle problem started which seems to be getting progressively worse. I called service when it started last week and nearest appointment was this Friday so just trying to make it till then. The alert on my ford pass app says possible improper oil usage or service but I haven’t changed oil brand in over 2 years and just had full oil change/service in late April plus added 2 quarts the day after this started. Any similar issues out there let me know
