Electric Window Problem
Reaper_247
Australia
Hi Everyone,
I have a 2014 Raptor and have an issue with the LH Front window.
I am in Australia so the LH window is the passenger side so it only has a single switch for up and down.
The master switch for all 4 windows is on the RH door.
The single switch on the LH door works both up and down with no problems.
The RH master switch works perfectly on all windows except the LH front.
If you pull up on the switch it goes down, if you push down on the switch it goes down.
I replaced the master switch thinking it would be the issue but the problem remains.
Any ideas where to look?
95,126
58,564
JustBud
