tahitiansoul
Hope they will make also a set for the gen1
I have mine in the box and get enough time right now to install!!!
excellent endorsementFront's higher than the rear.
Small bumps are way more jarring.
Feels unpredictable off road.
So I'll chime in after installing the Eibach Springs. They indeed raise the truck quite a bit. A lot more than doing mid perch on my 14. My question to Eibach is this: Did you take into account the Torsen limited slip diff? It seems like the height of top perch on Gen 1s which negatively impacted the Torsen. Also, how much sag should I expect? As of now it is higher than the back. Will it become a little softer. Small bumps are way more jarring. It also feels a little unpredictable off road sometimes. The definite plus is less nose dive while braking though. Just unsure what to think of them right now. Also, seems to be confusion on the if they are progressive?
---------- Post added at 10:54 AM ---------- Previous post was at 10:53 AM ----------
Last thing: I took it to a pretty reputable suspension shop after to see if it needed an alignment. They claim it doesn't after putting it on the rack. Could that be correct? Seems like it should need some adjustment.
I would definitely get an alignment. The caster and camber change with the height. Sorry to hear about the ride. Eibach's have always been pretty plush in the past.
excellent endorsement![]()
Comparing the support beam to the roof line to the truck it appears to be perfectly level.So I'll chime in after installing the Eibach Springs. They indeed raise the truck quite a bit. A lot more than doing mid perch on my 14. My question to Eibach is this: Did you take into account the Torsen limited slip diff? It seems like the height of top perch on Gen 1s which negatively impacted the Torsen. Also, how much sag should I expect? As of now it is higher than the back. Will it become a little softer. Small bumps are way more jarring. It also feels a little unpredictable off road sometimes. The definite plus is less nose dive while braking though. Just unsure what to think of them right now. Also, seems to be confusion on the if they are progressive?
