Eibach lift springs
dude1782
PHX, AZ/SLO, CA
wow is right , this does look better than collars or spacers. the pic looks level but I thought 1.5 was level?
1.5" is slightly under level and 2.5" is about perfect. However as others have said, when the truck is perfectly level any load will cause it to sag.
---------- Post added at 11:40 PM ---------- Previous post was at 11:39 PM ----------
Damn, this is could be a real option.
2.5 inches would make the front sit up a little right, or would that be level?
Who will be first? I am waiting for my truck to arrive.
2.5" would make it almost perfectly level
ChevyChad
Damn, I just ordered the Icon kit last week. This looks to be a better solution. Oh well...
Ecoop
California
Eibach says they will be ready the end of the month, I think those coils with SVC Coil Adjustment (already bought, just will install them lower) will be perfect with denver +3 in the rear.
Sitdown
Suburbia, IL
I pre-ordered my set a couple weeks back, best eta I've seen was end of June.
Someone else spoke with eibach and posted regarding its effective height. The 2.5" they note is not the expected height increase, but rather they are 2.5" longer spring. The posted stated they expect the springs are closer to 1.5" of actual ride height difference, so about the height of the BajaMod spacer Setup, or .25" more than RPG 1.5 collar
The RPG 3" collar gets to approx 2.25" of height, which IMO, I think is ideal. These progressive springs with the Svc adj collars might be a great combo to get best of everything (assuming they perform as described). I wish the svc system was more readily avail, had these shocks off too many times already ;)
[edit... the springs may in fact provide 2.5" of lift, per Eibach rep post below. Hope to confirm once installed]
