reaper1441
- Joined
- Feb 4, 2018
- Posts
- 350
- Reaction score
- 207
why does this guy think the recirculation tube for the BOV that mounts behind the air filter, next to the PCV vaccum line and in front of a turbo isn't under vacuum?
Sure, drilling a hole in the charge air cooler works... at drilling a hole. But nothing else has been proven with anything close to a technical or scientific method of testing. conjecture, internet rumor, and youtube videos don’t amount to proof.
You seem to be convinced that holing the CAC is not viable only because if EPA so surely you have some evidence to back this up - original source material from Ford, with Ford letterhead?
If you have 200,000 miles on the truck then the warranty isn’t much of a concern now is it?
EPA is not the only concern, your proposed and advocated solution presumably dumps fluid on to pavement. The contents of the fluid could contain engine oil that would otherwise get burned in combustion. Putting slippery fluid onto pavement people use to drive on could compromise traction, both for you and others. This would get you black flagged on any NASA, SCCA, or other sanctioned road course, assuming you got past tech inspection, which you would not. You would similarly run the risk of being booted from a drag strip, again, for the same reasons.
What are you missing about the weep hole?
Still, you have not done your research about why people resort to this on their ecoboost. Ford can't fix the stutter / misfire. Owners were left to figure it out and the weep hole fixed the issue.
You have never said why you don't agree with the weep hole. Sure, it's a boost loss, but very minor based on the testing done.
Warranty - again, find me someone that had warranty denied for this.
What are you missing about the weep hole? Still, you have not done your research about why people resort to this on their ecoboost. Ford can't fix the stutter / misfire. Owners were left to figure it out and the weep hole fixed the issue.
you do know that you are expelling metered air right?
the system is expecting that to come back through the motor.
electronics might be the bees knees on todays engines and have the ability to stay running, still not ideal unless you can adjust the ecu to atmosphere blow off parameters.
edit-the recycled air goes into the box before the maf my bad!
Facts. They’re stubborn things. And they’re missing from 100% of your postsThat is a tall order for sure. Seriously, you could end all of this by
providing some source data, on company letterhead owning up to the problem you describe and discussing this as a possible fix. Source data shouldn’t be so hard to find, you just posted this holing of the CAC as a workaround was only not permitted because of EPA regs. So, show us the proof. This is not that big of an ask, especially for an ecoboost enthusiast such as yourself.
failing to do so after repeated attempts is your tacit acquiescence that you are, in fact, a liar. You’ve repeatedly claimed this is a known fix and pretended to have inside information. Not links to forum posts on the internet(unless they have pictures of original source data, sporting company letterhead describing the problem and this as a proposed fix).
Don’t be a liar. post up the source data that proves what you are claiming.
Only that’s #Fakenews. Another Raptor owner resolved the alleged stutter with a transmission code update. See the thread by ‘03Darin, who has taken the time to troubleshoot the issue, and it is -not- a misfire.
Of course you know this, but stuttering acceleration is not always a misfire condition. What you are suffering from, besides multiple personality disorder, likely undiagnosed, with a touch of paranoid schizophrenia sprinkled on top, is called confirmation bias. You read about this phenomenon on the internet and now it’s everywhere in your perspective. The problem is that your perspective is divorced from reality. There are millions of ecoboost owners not having the issue you claim to be describing. Further, it has not been proven that this affects any of the direct / port injected ecoboost. Your advocacy for holing the CAC is not logical without any actual troubleshooting.
This is why you have zero believers here.
Seriously, you need to get medical help. When one of your passive personalities posts here, and your dominant personality follows up, you miss obvious things like the fact that I just explained why your suggestion is objectionable in the text that you quoted.
Multiple personality disorder can be mitigated in some cases with medication. You should pursue this remedy.
No. You haven’t provided a shred of evidence, only links to internet forums full of essentially anonymous posters. I’ve already passed your drivel by a Ford mechanic and documented this will void a powertrain warranty, so that’s enough for me. Others here are free to read this and make their own judgements based who they think has credibility.
Sooo... You have never heard of the ecoboost misfire? The ecoboost stutter / shutter? Ford's many failed attempts (have you seen all the TSBs?) at fixing? Seriously, you say you research the ecoboost and never found anything about it? I know you are stubborn, but you are not that stupid.
The weep hole for ecoboost... Google it and see what you get. A bunch! Have you realized that every f150 forum has advocated for the weep hole? Owners do it and problems go away.
Ford can't do or advise because the oily mix is against the EPA. However, through the various TSBs, it is obvious that Ford acknowledged the water buildup issues in the intercooler. All of their fixes were to make the cooler less effective in an effort to reduce water buildup.
Still, not sure what you are missing, or why you can't cognitively think through this. It really is simple. Go to any other forum and looked at the mega huge threads about the weep hole success. Again, this is for engine misfires... I never said it fixed anything else.
You keep wanting to say that you’re right and everyone else is wrong and that all the posts on the internet prove you’re right.
Proof is what’s being called for, actual proof, on company letterhead, showing that drilling the CAC is a viable answer but that EPA prevents the manufacturer from using that as a fix.
you can keep trolling, registering again and again and again, but you repeating the lie over and over doesn’t make it true and you are so obsessed with this alleged phenomenon that you are incapable of going for any significant time without trolling about it.
Post up the proof that Ford knows this will fix the problem, but they can’t because of EPA. Surely, you have Ford documents you can share.
Don’t be a weasel and say ‘just google it’. Put up.
Seriously, you have some issues you want to deal with. Do you even understand your question? It makes zero sense. We know that Ford can not sanction the fix. However, Ford acknowledged that the cooler makes water, and that was what was causing the misfire. You cannot argue that. Ford tried to fix within their means and that didn't work. Owners determined the solution was to get the water out of the cooler pre-spark plug. This is where the weep hole came in. What about any of this are you arguing?
Did you research other sites and read the 'sticky' threads detailing the proof that the weep hole solved the problem? I am guessing you are too arrogant and stupid to look for yourself. I am sorry that your jaded thought process can't think outside the box and try to understand this. I guess you have proven your idiocy by not being open minded and think something through.
