dual color lightbar
2014RubyRed
Galesburg, IL
Well, @tomahawk did it with a 32inch and f150 LEDs did it with a 32inch. I'll take some measurements tomorrow. It is pretty tight from what I saw in the videos
---------- Post added at 08:36 PM ---------- Previous post was at 08:36 PM ----------
I guess a 32 inch did work
Hey - give 'er hell then. Good luck......
Reptar
Jersey
measurements aren't consistent on these light bars. Some brands are slightly wider than others, some measure just the lense, some measure including brackets, etc. There's a chance the 32" is exactly the same size as the 30", just depends where they're measuring from.
srs
Tomball, TX
I did it with a 32" curved bar on top and a 42" curved on the bottom. Fit was perfect for both. Cheap Amazon bars though.
SVTLOPEZ
Perfect! Hey bro how did you wire them up? To an aux (which aux) or did you use a harness with a on and off switch?
srs
Tomball, TX
How the hell did you do that? Lol I'm a noob when it comes to wiring shit lol
There are several threads on here somewhere on what I did. If you are not using your factory Aux switches then just go straight to those, very easy, even if you're not a wiring guru. Information on that can be found on here, in your manual, or google search. Mine up top look like this:
SVTLOPEZ
That looks fckin sick bro
