would you recommend a fender washer or star washer?
probably fender washer
you haven't had any issues with the fender washers? my bars just came in today. planning on putting them on tomorrow night. can you send me pics of the install? 281-330-9029.
cant wait to put these on
no problems so far
and you didn't have to drill another hole or anything like that? did you put a washer on both sides of the grille bar?
no just used the hole that's aleady there...just look under your hood you will see the middle hole that you can use
I have found that the factory hole location mounts the light too low, and the grill blocks much of the light. I drilled new holes 1.25" above those and light output is much better.
I may try that
