wheelman55
I'm still doing a bunch of research, but I'm leaning towards using GBS LiFeMnPO4 cells. 4x 200Ah cells in a 4S configuration weigh ~55lbs and measure ~20" x 5.5" x 10". 4x 100Ah cells in 4S weigh ~28lbs and measure ~11" x 5.5" x 10".
I likely will run a BMS (or some sort of protection circuit). I'm still researching this aspect of the project. There is a lot of info out there, but it's scattered everywhere lol. I'm an engineer - but this isn't close to my area of expertise lol.
I did consider an AGM bank; however, I've had an itch to build a LiFePO4 bank for a while. This is something that might get moved to a small off-road trailer at some point (when I find a nice M1101/M1102 lol) and is more or less a fun project to me. Given the Raptor's limited payload, I wanted to keep things light and compact. Ideally, I'd like to be able to mount everything under or behind the back seats.
I should note that Ideally I want the ability to have several days power for times when I'm camping in one location and relatively shaded (i.e. not able to make much use of solar). I wont have a ton of things running on it, but a fridge does take some power, and I'll probably also want to wire in a WeBoost 4g booster and some low power rock lights to use around camp.
I should note that I don't need the benefit of LFP's high discharge currents for any reason. I'm not trying to run an A/C off the thing or anything lol. AGM would suit my needs, I just want more power at less weight/space.
Nice dims and weight. AGM would be 125-130 pounds and more than twice as large.
Are you active on Recent Discussions — northernarizona-windandsun
Keep us up to date on the project.
PS. I'm living off two 6V T105RE's for my extended overlanding. I can go five days running an ARB 47 liter fridge, daily charging a laptop, two iPhones and two iPads.
That runs the bank down to 55% SOC after five days. My bank is 225AH @ C20. So I use approximately 100AH when he returns n the bank down to 55%. Your bank should have plenty of power.
The ARB has a very low draw, less than 1 amp per hour. What does the Dometic draw?
