DRL Disable Canada
Aaron
Meme Corps Commandant
WA
So just push them through the grille and then add an inverter somewhere under the hood and I should be good?
TMAC3
Ontario, Canada
Hi there. I have tried to find this to no avail. What modules do I disable to have DRL turned off, and what else do we change to have that "Exterior lighting" box on my instrument cluster. Heres a pic from my dealer using IDS.
Doesn't the Forscan program allow you to disable the DRL as well as double honk and other features?
Seems to me that this would be an easy fix.
F
fidds22
Alberta
Yes it does. But i was at my dealership and they were hooked up using IDS. Supposedly you can do it with IDS, but they did not know how. So I got ForScan, just waiting on my ODB connector.
Sbautz
I also live in Canada and ran into this problem. I could turn off the DRL'S but the markers also went off... not sure we're to go from here
F
fidds22
Alberta
Still trying to figure this out myself. I got FORscan, and license, got adapter, but it wouldn't work. Had to order a different kind. Ill get this figured.
