m3dragon
Added to the shock build.
When you put the hat back on make sure where the GREEN dot is shown lined up with the green dot on the shock. It is generally above the place where the needle goes to charge the shocks.
Failure to do this means the lower bolt will not be aligned correctly with the hat orientation. So you get to pull it out, re-compress the spring and spin the hat. Not that we did this of course...
