DIY stereo upgrade for under $500.00
well done. Didn’t Guy get a couple tools to make the trim removal easier as well?
Just checking. I’d take a hard look at stepping up the bass a little more than the 300w Kenwood. It’s enough with the gain almost all the way up, but I think a 10” ~450 - 500w might be more suitable to what we really need here.
Toadster
Folsom, CA
Yes but it won't fit in the Sony sub box [emoji23]
G
Guy
I tried to figure out a way to convince the stock enclosure to hold a 10.... just not gonna work out.
I considered making an enclosure with relatively the same dimensions as the stock one, but with the surface area to mount a 10.... but the clearances are SO tight to do it in wood... means pulling out the rear sound deadening.
Wrapping the stock enclosure in dynamat, inside and out, wth a small amount of polyfill made a big difference in the sound... it's worth it for 35 bucks.
Give that a shot
Mcdonaho
Richmond, TX
Correct List can you verify?
I am a newbie on the audio side of things been following this thread and going to pull the trigger on the audio system. I am going to have a friend install it all as he is more familiar with audio installs. Can someone take a quick minute and look at my Amazon list and Crutchfield list just to verify I got everything and didn't miss anything! This would be much appreciated. I was thinking of having him do the Dynomat but wasn't sure what to purchased if you can help with that as well be awesome. Thanks!!
Toadster
Folsom, CA
looks pretty complete - the Dynamat is really simple to install - even if you just do the doors it makes a big difference!
https://2017-ford-raptor.blogspot.com/2017/04/600-for-premium-sound-system-is-it.html
it's basically an extra layer between the metal door panel and the door skin
http://www.youtube.com/watch?v=XUM360veHag
