I know there has been lots of discussion about resetting the KAM learning to improve tranny behavior, idling performance, etc., but I think it is worth mentioning again. I’ve had my 2019 for a couple of months, and I recently encountered a number of issues that will be the subject of another thread once I know how it all will come out. As a result of these issues, I decided to disconnect my battery to make 100% sure that my KAM was reset.
This is a stupidly easy and quick procedure that anyone can do, and I would encourage basically everyone to do it from time to time. In fact, my advice would be that it is the very first thing you should do when you get your brand new (or used, for that matter) truck home.
The truck has never run this well. The tranny is like butter—far better than the day I drove it off the lot brand spanking new. Idling is better, throttle response is better. It’s just fantastic.
Just my PSA for the day. Of course, YMMV. But I’m putting this into my regular maintenance routine.
Remember: Negative off first and on last. Remove wires from both terminals. Turn on the lights and open the doors or touch the positive and negative wires together to drain every last angry pixie from the system. Then reconnect and (optional) do an idle relearn: https://www.morepowertuning.com/how-to-idle-relearn
