Dinoone's 17 Avalance Grey Build!
Bullishone
Looks insane. I'm not 100% on the color, but let's see it all.
Sent from my Nexus 6P using Tapatalk
---------- Post added at 05:52 PM ---------- Previous post was at 05:51 PM ----------
I might have gone gunmetal, which is likely what I'll do. Do you have the setup for these wheels? Any chance you'll share?
MTF
Celebration, Florida
Hey @dinoone, Do yourself a favor and call Race Technologies. Ask for Barry
You have the rotors on backwards!
Which direction should the discs rotate? | Race Technologies | Brembo Official Partner
It is a popular misconception that the slots or drillings in a disc determine the direction of rotation. In truth, for an internally vented disc, the geometry of the vanes dictates the direction of rotation.
There are three vane types in use:
•Straight
•Pillar vane (comprised of many small posts)
•Curved vane
The first two vane types are non-directional, and can be used on either side of the vehicle.
The curved vane disc, however, is directional.
A curved vane disc must be installed with the vanes running back from the inside to outside diameters in the direction of rotation.
Orienting the disc in this manner creates a centrifugal pump.
The rotation of the disc causes air to be pumped from the center of the disc, through the vanes, and out through the outside diameter of the disc.
This greatly enhances the disc's ability to dissipate heat.
Additionally, all of Brembo's slotted discs are directional as well, regardless of the vane geometry.
The discs should be installed such that the end of the slot nearest the outer edge of the disc contacts the pad first.
They should be facing like this:
Also I liked the Pagid brake pads the best, it produced the least brake dust. They are pricey though.
dinoone
dinoone
Thanks man. There was no installation instructions so we googled photos of installation on another F150 and that's the direction they are going so we followed suit.
Going to give them a call in the AM thanks again
•Straight
•Curved vane
The first two vane types are non-directional, and can be used on either side of the vehicle. The curved vane disc, however, is directional.
A curved vane disc must be installed with the vanes running back from the inside to outside diameters in the direction of rotation. Orienting the disc in this manner creates a centrifugal pump.
MTF
That's my Tahoe, I had those Bembos on both my wife's 4Dr and my 2Dr.
For many years.
Replaced rotors and pads every two years, I got good at it.
Also you have to do the burn in procedure ( brake pad bedding ), I cannot stress this enough you can warp the rotors right away if you had to do a panic stop
dinoone
dinoone
We looked at the vanes in the rotors they are correct according to the article.
Please let me know the bedding process
For many years.
dinoone
dinoone
Passenger side vanes.
32911802440_acb0c27116_k.jpghttps://flic.kr/p/S9iAeE
For many years.
