Dinoone's 17 Avalance Grey Build!
MTF
Celebration, Florida
The close up picture of the vanes direction finally worked and they are the correct way.
Did not know Brembo changed the design, this must be the way the 15 inch rotors are.
MTF
I'm guessing you have the big 15 inch on the front and the 13.1 inch on the rears. The rear ones look exactly ( even the hat is the same ) as what I ran on the front of my Tahoes.
If you look at the rear rotors you will see the drilled holes go across the vanes not like the 15 inch were the holes are in the same vane.
Your rear rotors are wrong according to the picture.
But if you're going for looks I guess the back rotors being in the wrong direction is really all that critical.
dinoone
dinoone
Thanks we fixed it after we got the fronts sorted out!
Bullishone
22s on 37" Open Countrys
Do you have larger images of it? Did it rub anywhere and how high was the truck? I'm about to order HREs likely 20" on 35s but I might go bigger.
Sent from my Nexus 6P using Tapatalk
