Decided to go mid travel
Turbogoat324
SoCal
I feel like majority of people spending 15k+ on suspension are planning to offroad pretty hard. There’s much cheaper ways to make your truck look similar but if you’re investing that much into your suspension I’m sure you’re using it! I’m over here all proud I finally saved up and got fox 3.0’s but I’m not even in the same league as you haha. Let us know how it feels once you take it out!
DeltaRaptor
That was my builder taking the truck for a test drive. He told me about that. Heard u almost crashed
Nahhhhh….Not even close. I probably got a few inches off the ground though. :) There's an infamous dip right there that I always take SUPER fast.
We should line them up though and run'em!
Dachuri
Memphis & Austin
OP, I just installed King 3.0 coilovers on my Gen2 and I’m getting a rattle when I hit a hard bump on the road. Are you or anyone else getting a rattle from King’s?
Turbogoat324
SoCal
Most likely what you’re hearing is the rear external bypass valves. That is a normal sound from shocks with external bypasses.
G
GBRaptor34
Northern California
I don’t get any sound from the coilovers. But my race series shocks are noisey. Check and make sure everything is tight
Dachuri
Memphis & Austin
Yes, definitely not just external bypass noise. Rear sounds fine, passenger sounds fine, just coming from driver’s side coilover. SVC installed them and they’re more than happy to investigate for me. Dropping the truck off this coming Tuesday and hopefully will have an answer.
