Deaver upgrade to add payload - do I need leveling kit, too?
xrocket21
Maine
I’m surprised you have no squat- mine dropped 3/4” in the rear after putting a leer top on.
I think I might need the +3 deavers to bring it back up and get the better ride.
Any suggestions?
What do you have in the front?
The +3's will gain you 1" in the rear
xrocket21
Maine
All stock. With the leer cap, the rear dropped 3/4”.
All depends on what you want for rake. Adding the +3 will give you 0.25" more rake than stock (with the cap), so that may work for you. If it were me, I'd do a collar in the front, but thats me.
Winchester30
WI
That would probably work. Original stock height is fine for me. I just don’t want any more sag if I haul anything and want better handling in rear.
warrior
Your Wife's Personal Trainer
I have the deavers +2 and aextra leaf for towing, also added rpg 1.5 collars to level. Great upgrade, handling, ride and towing all improved.
zx14teryx
Deaver +2 will be stock height because it removes the stock 2" block. Deaver +3 raise the rear one inch. Whether to want to level or not is up to you. 2.25" front makes it level, 1.5" is still nose down.
Sounds like Deaver +2 HD with a 1.5" front collar might get you where you want to be? levelled a little, able to carry more load, but still a little nose down.
I run Deaver +3 with a 2.25" collar and it is a bit nose down.
Do you have Deaver hd? And how is the ride unloaded.
xrocket21
Maine
I have standard deaver +3s
I love the ride. Similar to stock , but they are progressive so when you take a big hit, they get stiffer. Losing the wheel hop as well as the rear chattter toward the ditch was huge for me.
zx14teryx
Not sure how often you will carry a load, but the Deaver HDs are stiffer than the standard Deavers by quite a bit when driving unloaded. I went with standard Deaver +3s and Geiser Springs in the front which raise it about 2.5". My back is 3/4" higher than the front and I have not had issues with sagging the couple of times I have loaded my trailer on the back.
I rode in a 2017 Raptor with Deaver HDs before buying mine and it was considerably stiffer than the way mine rides today.
How much tongue weight did you tow?
TXRaptor
It was small utility trailer with a tongue weight of 3-400 lbs depending on what I was carrying. The truck did just fine.
Just for fun, I put my 6800 lb TT with a 900 lb tongue weight on the back and my rear dropped more than 2” on its own. With my RPG Stage 3 bump stop kit which has 2” Fox Bump Stops at 60 lbs, 4” bump stop extensions and a Blue Ox WDH, I was able to tow the same TT reasonably well. It sagged less than an inch, but I would not recommend towing that much weight with a Raptor for long distances.
EDIT: This was a really old thread...:cool:
