Deaver Rear Springs Installed
Hoverp
Central Montana
On my 2014, I want deavers in the rear , just wondering if it got rid of the ""JARRING'' you get when hitting stuff like a single pothole at speed, or going over speed bumps , and the back of the truck does the jar, hop thing.
I'm stock, on 44 psi stocks tires.
2014RubyRed
Galesburg, IL
Yes, it will be an amazing improvement!!! Not traction bars or anything, but the rear end of the truck will seem planted over most of the things you will encounter on the street and the trail.
Hoverp
Central Montana
Thanks, sounds like a worthy investment!
How long did it take you to do the install? Did you drive way it? Or shop lift it?
2014RubyRed
Galesburg, IL
We did it ourselves. It was actually one of the funnest mods that we have done so far. You will need a way to lift the whole rear of the truck off the ground and then have an extra jack under the diff to raise and lower the rear end and independently. It was the first time we had done this, so start to finish it took us about 2 1/2 hours. Make sure that you recheck all of the torques after 50 miles or so as everything will set in and loosen up some.
Good luck, and if you would like a quote for the springs, let me know.
Sitdown
Suburbia, IL
Wish I had done the deavers on day1, best mod on truck hands down.
Consider paying a little more to get them powdercoated too. Had my 2nd set done and look great
just Mike
Colorado
Yeah, should have done something to mine. Three months in and they are rusty as crap. But now I'm too lazy to take them back off to get cleaned up.
Sitdown
Suburbia, IL
for those in the midwest salt belt, it's now a requirement from deaver
Hoverp
Central Montana
Yes, that would be good, deavers and shackles, powder coated. What model deaver with the camburg would equal stock ride height or a bit taller?
''Price check isle 3!''
