Deaver/eibach combo ?
K223
Florida
Thank you guys for the info on getting this recalibration. I tried downloading software for my foxwell scanner and that didn't work, so after reading a lot about what is actually required I called around to the local indy shops. No one could do it. I finally called the dealer who also said they couldn't do it and referred me to a roush certified dealer. That dealer was closed due to a COVID outbreak. I ended up getting my dealer to do it by supplying them with these instructions based on what you guys said:
I verified the ride height as seen above and it's good to go...Can't really tell the difference though honestly. Maybe once I drive it more.
Looks perfect now. It’s pretty subtle. I knew my ride changed after springs, but it took a while to realize, why the truck’s quality ride was degraded for the most part on road. Once calibrated it was smooth again. I guess you have to know your truck before and after the springs.
ljn21
Tega Cay, SC
Any dealers/shops in Charlotte area that anyone has used to have front springs installed and the ride height calibration completed?
dmb359
Minneapolis
Anyone do Eibachs + Deavers + SVC Bumpstop? Is it worth doing the bump stop?
Probably depends on your use if it's worth it.
I don't offroad much, and tow a travel trailer occasionally. I went with eibachs and Deaver +3HD, and the forged offroad bump plate, so I could use the factory bumps or put the timbrens on if need be when towing, but didn't do the SVC bump stops, as I didn't think it was worth the money for me.
RaptorVette
Corpus Christi, TX
I had the SVC bumps, RPG Fox 3.0's and Deaver +3 HD on my Gen 1.
I did NOT go with hydraulic bumps this time when I upgraded to Deaver +4 on my Gen 2. I have jumped the truck going around 70mph several times and it handled it just fine! I am just mindful of what type of situation offroad would cause the frame to get damaged.
K223
Florida
Do you keep static weight in the bed?
Chazzersgarage
Denver, CO
I understand that the ride height needs to be set on live valve (19-20) raptors and I understand how this affects the performance of those raptors. I also understand that a ride height calibration is not necessary for the 17-18 Gen 2's. Is there any ride height or other calibration that SHOULD be done on the earlier Gen 2's to ensure all of the electronics function correctly?
I'm relatively new to this and looking at putting the Eibach/Deaver setup on my 2018.
