Deaver +3 and Geisers/impressions and looks
Pat
Syracuse, NY
I just had Deaver +3 and Geisers installed this weekend and I wanted to give some first impressions.
Overall the ride quality is significantly improved. The Deavers seem a little softer than the Geisers in front, but not terribly different. The on-road manners are really good and the front isn’t overly stiff. I will be getting an alignment done tomorrow and don’t know how soon I can get them on the trail to see how they feel there.
The overall look isn’t as expected. The front is sitting a 1/4” higher than the rear, which is not the way I like it. I am hoping the front settles in a little but not sure if that will occur. The leveled look is good but I think the nose high looks a little goofy. I know 1/4 inch is pretty small, but it was noticeable right away.
The other thing is the ride height sensor is all jacked up as well. I am hoping the dealership can reset the sensor and clear the current code. Which says “drive mode selection unavailable, service required” (or something close to that). Right now I can’t change to any other drive modes or steering modes (like sport mode). I was reading that the dealer needs to reset the sensor to 0mm, which I hope will clear this current error/code.
If anyone has experience with the front springs settling a little, and the sensor reset, I would like to hear it.
Thanks.
Sharkus29
Kickin it in Canada!
My Geisers on my 2018 settled over half an inch, I had Deaver +2's on mine so my nose always sat a bit higher but eventually not by much. I traded in for a 20 not long ago and have the deavers and bump stop kit on already but i'm waiting for my new Geisers. Now that I read this I'm going to call my local dealership and ask if they know how re calibrate the ride height sensor before I put the new Geisers on
Brent M
Tucson
Thanks.
Brent M
Tucson
I have a 2020 SCREW looking at the same set up. You have any pics? There are a few other threads on resetting the sensor.
Brent M
Tucson
Thanks for sharing- please share any info from the dealer on the recalibration and how the springs settle overtime. Nice rig.
Maddog77
Vancouver,WA
Any updates? Did the front settle and are you happy with the upgrades now?
P
Pat
Syracuse, NY
Thanks for asking.
I haven’t actually measured since settling but I think the truck is prob about level now. However, I did take the spare out and just put it in the garage for now, so I estimate that’s about 100lbs less in the rear.
Still the same impression from when I first drove it. The front springs do still feel a lot stiffer than the rears. The rears are soft but really smooth. If I take a bump or depression at decent speed it’s smooth as shit! I do like that.
As for the lift, I still think I need a little more in the rear since I am currently running a Decked USA system with enough crap in it to add some weight for daily driving. I did not get camping this summer, so the RTT, spare and all my camping gear was never loaded out to see what type of compression I get on the rear springs. I’m gonna guess they will have enough to put the truck nose high.
Not sure if there is a spacer or some add-a-leaf (if that’s even sensible) to get a little more lift in the rear. But if you are looking for a level, yet aggressive look, seems like this combo will work.
I will try to get an updated side view pic and post it.
