Dealer visit tomorrow need input.
Bamachete
Birmingham
Going in to have free oil change after 5000 smooth miles! On my list to look at are: inverter fan noise, reverse brake sensors failure, auto rain sensors aren’t working. Are there any other TSB’s I’m missing? Thanks
Lowkey
CoronaRaptor
CANADA
Good luck, I hope you have a good dealer and get everything fixed to your satisfaction. You should of asked the dealer way ahead of time, what tsb's were current for your truck, just saying. There is the battery draining thing that was happening early on with the early 21 Raptors, not sure what your build date is, but @FordTechOne mentioned there was a tsb for the battery drain on the early ones.
HOLESHOT
Mid East Coast
Check the oli level after. Seriously, they put one quart to much when they did my first free oil change in my Raptor and didn't change the oil filter!
I checked it there on the spot, and they fixed it.
Broken Wrench
Canton GA
Yeah, my rain sensor wipers don't seem to work. Although they did at first but are not now, I bet a sensor is bad. Also, not sure if anyone has experienced this one, my SD has speed humps in it and every time I go over one at 25-30mph the emergency brake alert chimes, I set it to low sensitivity, but it is still doing it. no braking but it does give the audible alarm for a burst when I hit the speed hump. These are not huge, my ford Fiesta used to take them at 30 mph no problem.
Raptorial
US
I have never heard of the emergency brake alert. Does it still alert if you're in 4H?
FordTechOne
Detroit
Unlike recalls, dealers are not supposed to perform TSBs unless the customer has a concern related to the issue in the bulletin.
m4can2
Texas/Georgia
Rain sensors and courtesy wipe doesn’t work on mine either. Crazy how these trucks can have so may little issues.
