Day 4: quality issues?
raptorzz
Raptor Assault
Just want to list a couple things that I have experienced for past 3 days of owning the raptor.
- driver side window one touch up not working. Got to hold up to close window; At one point the window was going down on its own when pulled one touch up.
- Last night the bass on the b&o completely turned off. Music sounded like it came off of a phone speaker. It went back to normal after I turned on truck 30 min later.
-not sure if this is a ford or apple issue . But when using apple carplay maps, 50% of the time half the screen turns black and seems like it glitched. will upload pics later.
Not sure if others experienced this,
but i dont really mind any of it! Love everything about the truck, always a thrilling drive with exhaust on baja mode! As long as it runs and drives, I will avoid going to the dealer for these minor issues :)
ToadSmasher2K1
Home Is Where You Make It
KC
My passenger window did the same thing. Dealer had to re-learn the window and now it works fine. Maybe someone on here knows that procedure, might save you a trip to the dealer.
Keith88
Boise, ID
Window - This is common. Just needs to be re-learned as previously stated.
B&O Bass Loss - Normal. The B&O system is DOG CHIT. Replace the sub with an actual sub and you'll be happyish.
Apple Car Play Issue - Not Normal. Make sure your phone is at current update/software. Disconnect phone n reconnect. See what happens.
trav7314
Floribama
I came from a Tacoma. The B&O system is wonderful!
Keith88
Boise, ID
Anything is better than a Toyota IMO. I will say that the standard BOSE system that was in 20 AT4 blows this B&O system out of the water. Not even Close. The "Apline" system in my Jeep Grand Cherokee BLOWS the B&O away too. Its my only gripe with the truck...the stereo F--KING SUCKS.
FordTechOne
Detroit
CarPlay is very sensitive to the quality of the cable being used. Cheap aftermarket cables or worn Apple cables will cause CarPlay to have issues.
Window initialization is in the Owner’s Manual:
Resetting One-Touch Close
Carry out all steps within 30 seconds of starting the sequence.
1. Close the window.
161 2023 F-150 (TFD) Canada/United States of America, enUSA, Edition date: 202206, DOM
2. Press and hold the window control switch until the window is fully open. Keep the window control switch pressed for a few seconds.
3. Lift and hold the window control switch until the window is fully closed. Keep the window control switch held for a few seconds.
4. Press and hold the window control switch until the window is fully open. Keep the window control switch pressed for a few seconds.
5. Lift and hold the window control switch until the window is fully closed. Keep the window control switch held for a few seconds.
Note: Repeat the procedure if the window does not close when you use one-touch.
raptorzz
raptorzz
Raptor Assault
Thanks! i will try it
Members online
95,320
58,843
brucebarson
Latest posts
