Dad promised me a Raptor if I got accepted to the Air Force Academy; here I am
CoronaRaptor
CANADA
Welcome, your Dad must be proud of you! Don't let him down by doing something stupid . My Dad bought me a 65 Chrysler when I was 14 (learners license) and I took the car out one night and drove it on the airstrip on the base. The MP's came and took me to my Dad (MILITARY MAN) and handed him my license, I never saw that car again, but I did end up respecting him a lot more for not beating the life out of me!!
ReyLorenzo
Lake Mary, FL
Congratulations on getting accepted into the Air Force Academy. That's a great accomplishment. My brother inlaw went to West Point, and was also accepted into the AF Academy. Both exceptional schools!
SilentShooter
Siesta Key, FL
As someone who was accepted to the AF Academy congrats (Not an easy task), I instead went to Embry Riddle. I would definitely not go around mentioning why you are getting the raptor or when you get it how you got it. Will be a great truck to have in CO, but you do realize only eligible First & Second Class Cadets are allowed to have vehicles at the Academy.
Ditchplains1
Trescott, ME
Bowes,
Congratulations!
Since no one else has answered your query...Look for alignment of the bed and cab. Many stories of overdoing it led to bent frames. Taking a jump improperly led to bottoming out the rear axle on the bumpstops causing the frame to bend near a nearby frame opening. Trucks with this damage typically have the front of the box riding higher than the rear of the box. RPG, Icon, and others have frame strengthening hydro-pneumatic bump stops to prevent this from happening; SDHQ has frame gussets also.
Early Raptors had problems with driveline "clunk" from a driveshaft to transfer case slip yoke problem. Ford stepped up and issued a TSB to replace the drive shafts in affected trucks.
Power steering problems...the pumps are worked hard in our trucks. There are several companies, RPG, SDHQ, etc that have larger PS reservoirs as well as additional PS fluid coolers.
Lastly the front hub engagement is by way of vacuum, the default is to be engaged. Small vacuum leaks may lead to decreased vacuum which may lead to partial engagement of the front hubs which will destroy the engagement splines quite quickly.
Look for any signs of abuse...crawl under the truck...leaks from the transmission? Differential leaks? Bashed skid plate? Bashed transmission pan? Bent rear shock axle mounts? Loose wires or hoses? Brake fluid leaking? Evidence of frame repair from collision? (overspray, bad welds, body panels misaligned). Has it gone swimming? Evidence of being submerged...pull up the passenger side sill plates and look for silt/mud in the harness wiring.
As stated above the Raptor has thus far been a very good investment with little to no loss of value compared to other pickups. Look carefully, shop around, and don't jump at a deal that seems too good to be true....
Eddie
Wilson
South Dakota
I know of one with low miles 24,5xx not much off road just hunting white it's a 13 for 49999 at Watertown Ford Chrysler: Watertown, SD | New & Used Auto Dealer
---------- Post added at 12:19 AM ---------- Previous post was at 12:12 AM ----------
2013 FORD F-150 4WD SuperCrew 145 SVT Raptor For Sale in Watertown South Dakota | Watertown Ford Chrysler
They also have a black one with more miles less money.
Ps I'd be proud to say my dad bought me a raptor, do you work for him or is this a just becose?
Mjolnir
Colleyville, Texas
Hello all,
I'm looking into my options for a Raptor and I'm a bit overwhelmed. I've done quite a bit of research on the specs, but there's still a lot of unknowns that only come with ownership. I would honestly be happy with any year model, I'm just hesitant as to what issues may arise from purchasing a used model (how much off-roading, abuse, etc). Do you have any advice? Recommended year models? Websites for more info?
Thanks!:
congrats on getting into the academy!
SilentShooter
Siesta Key, FL
I would pickup a CPO Raptor this way you have the best warranty you can get on the raptor. If you can not get a CPO then be sure to get the ford ESP warranty. You do not want to be in college and have to deal with paying for repairs.
There are plenty of street queen raptors that were traded in so do not think all used raptors were abused. Hell most ones you see used with Bumpers and lights are street queens. The people on this forum are the exception in that we utilize the raptor for what it can do not just for how it looks.
