I will be installing the CVFab Titan V2 IC in a few days. Currently running through the instructions to make sure I have everything needed for the install. Looks like it’s a fairly simple install.
For the AGS (shutters) I am seeing “just trim” “just remove some blades” and on CVF website. “Remove the shutters”.
I am looking at removing the shutters completely. Is this the common process? I understand the reason for the shutters as well as the cons of the shutters. Just looking for info from those who have removed them.
Also it looking like you have to pull that grille off to remove?
