Custom High-End Focal Stereo Upgrade in a Tremor with B&O
W1N
Helsinki, Finland
In our higher end systems, we are using a DSP instead of passive crossovers. So it's all done electronically. If you are using passive crossovers, we recommend to never put them inside a door panel. Mount them behind the rear seat away from moisture, vibration and potential noise pickup.
Thank you for the info again. Will go through the video in detail foe sure! Great add!
Doesn't that mean that new speaker wires needs to be installed or there already are separate stock wires for the tweeters and mid-bass in front doors if I want two-way active system? Is it same for the rear doors even though they are coaxial?
I prefer using DSP for whole system as well.
W1N
Helsinki, Finland
That's tough, we typically run two 5-channel amplifiers for the entire system. To add a center channel, we add a 2-channel for the center.
Here is a typical 3-way active setup rack:
Do I get it right? For full active system there would be 4 channels front (two-way active both doors), 4 channels rear (active coaxial speakers both rear doors), Center (1 or 2 channels?) and Subs?
For center do you bridge the 2-channel amp or is the center actually two channels? Is center one or two speakers?
rlj676
Detroit
I think there’s something that needs to be done for the tweeters with running a wire as there’s another amp in front of truck I’ve read. Could be wrong about that (hopefully).
I’m actually interested in a 5 way active using just 2 way fronts no rear filler…
Soundsgood sent you a PM, but please add to the thoughts a 5 way active with smaller 4 channel mosconi dsp amp
W1N
Helsinki, Finland
Found these on another forum. It looks like there is lot wiring ready and Soundsgood has products ready to build fully active system that retains all speakers including headrest speakers and roof speakers.
rlj676
Detroit
That means you have lots of useless junk in your truck traveling around
Do you mean me or those crappy little speakers lol?
If I had unlimited budget I’d do 3 way actives in those awesome a pillars front only, still leaving all the junk. Those extra speakers are pure marketing material fodder, do nothing of value in a quality stereo system. I’ve worked at Ford and GM in electronics, the goal isn’t best sound but how to advertise more speakers in dumber places (seriously). The requirements are never flat music reproduction in all seats or anything useful. Meaning that money that could be spent on fewer but higher quality amps and speakers is wasted on paper cones and wiring harnesses all over the place.
If you are going to watch movies and want Dolby atmos they make a lot of sense I guess.
W1N
Helsinki, Finland
I agree. For me the goal is to try to retain factory type of sound system, but with better quality speakers. All speakers can be updated except the ones in headrests. I don't want to go full retard, but add more bass, kill all rattle and make the cabin more settle.
rlj676
Detroit
I am pretty sure it will turn out awesome, your whole truck plan makes us all envious I think. Will really be a standout in Finland. I’ve always wanted a full size truck in Europe just to turn heads lol.
W1N
Helsinki, Finland
Thank you! It will be blast to have one, but even more so I will enjoy finally able pack family stuff to go when heading to our vacation.
