Custom High-End Focal Stereo Upgrade in a Tremor with B&O
DCM
Does the battery for the Pro Power system impact the space available for the amp rack behind the rear seat? Whats the lead time from order to ship on one of these packages? Most interested in a 2-way active package.
SoundsGoodStereo
SoundsGoodStereo
F-Series Stereo Specialist
Nashville, TN
Send me a photo of the Pro Power system battery behind the seat just to make sure. Regarding the package shipping, we are finally catching up and expect 2-3 weeks from today on the 2-way active package. Be sure to choose the Four 6.5-inch Vented as your subwoofer option and let me know if you have any questions on the speaker series.
DCM
Still waiting on truck to ship, so no pictures available yet.
SoundsGoodStereo
SoundsGoodStereo
Nashville, TN
Our racks go all the way to the factory jack, so depending on where the battery is located will depend on what modifications we will need to make for you if any. Just let us know or if you can find photos, send them our way.
SoundsGoodStereo
SoundsGoodStereo
Nashville, TN
So our rack does not mount in that location and even our enclosure does not utilize that space. So you are good to go unless behind the seat, it's different which I assume it's not.
rlj676
Detroit
So either your stealth or under seat subs fit with pro-power?
I assume the under seat has way more volume as well as 2x the subs, so quite a bit more output potential.
I’m interested in good quality but lack a golden ear, and really do like bass lol.
Keith88
Boise, ID
Is it possible to just add a sub to the B&O unleashed system without spending a trillion dollars?
SoundsGoodStereo
SoundsGoodStereo
Nashville, TN
Yes, all of our plug-and-play systems including the stealth packages work with the Power Pro pack. We just need to know so we can configure the amplifier rack correctly. Behind the rear seat, you will see a vent tube that runs from this battery to the rear c-pillar.
Regarding performance, space makes bass, not the size of the woofer. If you are willing to sacrifice under seat space, our enclosure which we have years in development will deliver across the board on performance. The behind-the-seat setup is great, but not a high-output package. It delivers more than anything else that actually fits behind the seat, but will not compare to double internal airspace enclosures.
What always stands out from our enclosure is the frequency range. Our enclosure will play well into the lowest spectrum of music (30hz) where as other enclosure manufacturers tend to leave this range off the table. Our team is all about the music, and the performance. Having a stereo system delete part of your favorite song is not what we are about.
SoundsGoodStereo
SoundsGoodStereo
Nashville, TN
lol, many different ways to approach adding bass to the unleashed. Here are the options we believe deliver what customers are looking for. Be sure to use the Year/Make/Model/Etc to narrow down the options.
