Custom chase rack
Az Scooter
Why can't you just weld it yourself? I am not the best welder, but I can grind with the best of them.
skyscraper
Welding is the easy part. Its the layout that most wont be able to do unless they have experience.
Az Scooter
Layout is a ton easier if you have a design, and a layout table. They are only about $125 for a cheap one.
johndjmix
Very cool man. The one im making for my truck is 1-3/4 round DOM tube, but the square is cool...modern and different. Also, its much easier to work with since you dont have to notch and the main hoop can be 3 pieces instead of having to do bends like with round.
Yours is pro level perfect, but using square tube it would be possible for a guy at home to make a rack with just a welder and grinder. You may have started a trend!
Ill post mine when im done in about a month...(Been to busy to work on it)...
--John
