Custom Built Super Charged Raptor!
Whipple Charged
You can find them online.
Excellent build.
We have these in stock, since these were a copy of ours. We have twin 68mm which is the ideal choice for daily driving. We also have our version of the mono blade and our super mono blade which significantly outflows this unit but may be a bit over-kill for this project.
Biggest
Biggest
Excellent build.
Great, I called your company yesterday and inquired as to which belt I would need in order to run your 2.750 pulley. I was told that you did not know.
After figuring it out the correct belt size is the Gates K061247. On a side note the belt that comes standard with the 3.50 pulley fits, however, we get experience some slip at high rpm.
That being said the Gates K061247 is the correct size.
Whipple Charged
If the idler setup is correct, there is no slip. If the tensioner hits the stop, then you will get some slip. We use the 124.7" belt for smaller pulleys, down to 3.0". Then a larger OD balancer is required, which then puts you back at the stock belt unless you go to the 2.75".
