Crank vent tube
robjenks
Austin Tx
So the 24’s have those 3 posts at the bottom of the crank case plug on the intake to remove the hose to swap out the Intake. On the 24 that green DC tool does not fit around the tube with those fins. Anyone have a work around or do I need to just dremel off those fins to get access to the tube for the tool?
RaptorMX
Mérida, México
I had the same issue. My green metal one didnt fit. Then i bought the same kit on amazon made out of plastic, i cut the tool in 2 pieces and then i easy could remove it.
Btw which intake you gonna install?
Burt
Auburn, CA
same issue here, ended up breaking one of the 3 tabs on the inside, put on a SPE intake. No easy way to get it off and SPE told me "no one" has ever had a problem with getting it off, basically told me it was all me.
Just threw a coed P2C90 Crankcase Ventilation System- Hose "A" Disconnected.
I ordered a new hose today, hopefully will fix the issue.
RaptorMX
Mérida, México
Buy the plastic one and cut it in two pieces. Easy to remove then
RaptorMX
Mérida, México
Does your SPE intake also rub on the coolant tube?
Burt
Auburn, CA
great idea - I will try that
it was - I was able to push the adapter hose further onto the intake and the intake further into the adaptor and gained about a 3/8" gap from the cooling tube - tried o adjust the coolant tank but wasn't able to gain any clearance there
jk47
illinois
Did the new hose fix your problem. I am having the same issue…
