COBB tuning Raptor tune
COBB Tuning
Austin, TX
I appreciate the run down. That’s what worries me with tuning this motor. I trust the tune more than the motor. If something happens out of sheer coincidence, not even tune related, I’d pretty much be screwed.
So, that’s a hard no I couldn’t use all the other features of the AP unless I wrote a new tune to the truck?
Right. You would have to flash a map in order to use the features.
When the Accessport is properly uninstalled using the "Uninstall" option from the main menu, the ECU is reverted exactly back to stock. In our experience, the dealership is not able to tell if the ECU has been flashed. However, with that said, the AP is not designed to go around any kind of warranty coverage and there may be diagnostics at a much higher level we are unaware of. At the end of the day, it really comes down to how your local dealer handles modifications to the car: some don't mind a few mods and others don't like any.
Kyle@COBB
Obscure
Kyle@COBB
I feel like this is a tad misleading... At the end of the day, it isn't how much your local dealer cares about modifications, it is how much Ford cares as they are the one footing the bill. Ford is the same company that tied Whipple's hands by not allowing you to easily switch back to stock once you put the Whipple tune on it. If you have a catastrophic failure while running a tune (even if the tune didn't cause it), I'd be prepared to be paying out of pocket for a new engine.
texasflyer
Darkhorse99
Wichita, Kansas
Kyle@COBB
I appreciate the update.
cao0215
Cool, i ll go get the dp, combine with my existing svc intercooler
