COBB tuning Raptor tune
COBB Tuning
Austin, TX
As others said this is a little misreading. They will simply check the key cycle and see your 2017 has 10 key cycles on it since last flash which most likely was at the factory 2 years ago.
It would also look the same as 10 key cycles since your last battery terminal disconnect which could have happened for a number of reasons. I think my statement is straight-forward but to make it more clear, if maintaining the warranty is a priority for you, don't flash the ECU.
Kyle@COBB
Thor2j
US
Kyle@COBB
That's not true on the FOCUS RS is it different on the Raptor??
Dirtypope
Chicago
Can u get the Cobb intake that is designed for 17-18 for 2019 or should we wait till the Cobb Accessport is released with the intake for 2019?
FORZDA 1
Gloucester, VA
Uhmm, that's the way it works on my 2017 Focus RS. If you disconnect the battery for several minutes to allow the capacitive volatile memory to bleed down, all that type of info is reset to zero. The way the dealer questions whether you "had" a tune on the vehicle is with the number of key cycles since last reset. The dealer can't read the previous tune data at all. Cobb is quite correct in their suggestion that if you're really concerned about your warranty, DO NOT install a tune. Pretty simple. The Cobb tune(s) aren't going to cause any engine damage, but other things may fail as they normally would and result in you wanting warranty service.
Basically, if you can't afford to pay, then don't play.
Nick@Apollo-Optics
If the COBB CAI is installed on a 2017 model without the Stage 1 ECU Map, it will throw a code. However, the tolerances are lower on the 2018 model and the COBB CAI can be installed with the OEM ECU map. No word on the 2019 model yet and how it plays with the OEM ECU map.
Thor2j
US
So you are saying if you add 50+ hp and or 75ftlbs tq there's no extra motor wear that may cause a failure prematurely????
That's comical.
Fyi, my focus rs is tuned. I'll take the chance.
