Just Purchased Cobb Accessport
CJ Knipper
Myrtle Beach, South Carolina
Just got my first Cobb with shelf ECU and TCU tunes. Question is about throttle control... For anyone who has done the shelf tunes, do you also need a throttle controller for that off the line feel or does the tune handle that?
MarkM98
St Louis, MO
I have not used any of the Cobb maps that come with the AP. I waited and then got with @GooseTuned for custome stage 1 tuning. I’m almost done with that with him and I can tell you the throttle response is so much better! Once my tuning is complete I will post about it more.
icecoldak
You have to set your dynamic throttle response to the way you like it---goes from stock to 10! I set mine to 3 and its perfect I think. Its a separate setting in the access port, just play with the diff numbers and see what you like
AND I would get with Winfield (goosetune) and get you truck PRO tuned with him, as it will pick even more power and smoothness! get his TCM tune as well, much better than COBB TCM! Also as I did when you find that magic dynamic throttle response number you like he can add it into your tune and iy will always be there!
