Have you pulled DTCs?Still no return of the tones thru the audio system, been thru several key cycyles. I have not reinstalled the Cobb ECU and TCM tunes yet. Is there a Forscan Solution?
I went in an cleared any DTC's there were. In the process of upgrading audio and have replaced right rear speaker so far. Just reinstalled the ECM and TCM tunes and still no tones.Have you pulled DTCs?
Did any of the DTCs return after clearing? That would mean the fault is still present. I would also try running a self test on the APIM, ACM, and IPC.I went in an cleared any DTC's there were. In the process of upgrading audio and have replaced right rear speaker so far. Just reinstalled the ECM and TCM tunes and still no tones.
Ok, tones have finally returned to the Audio System. Just needed a little patients, whew.FTO has you covered. If there are any codes for the APIM/ACM it will send the tones thru the IPC. Most of the time this is just a communication issue when installing that tune that you can clear or it resolves itself, but a bad speaker/connection will also cause it
