GEN 2 COBB Accessport - Tuned by GooseTuned
Alysium
California
can you run regular 91 on the HPFP?
Like, run e85 on the e85 tune then if its not readily available switch back to regular pump with a regular 91 tune?
10SpdsOfFury
Jacksonville FL
The HPFP is like driving a Ford GT, yes it will go 200mph (E85) if you need it to but will also cruise all day at 70mph (91/93oct). :)
TwizzleStix
Commivirginia
Just some FYI about the XDI HPFP. You can't just bolt on the XDI HPFP and take off. It requires a few changes in the HPFP configuration tables such as the Fuel Volume per stroke and XDI driver setup for their Mass Flow Valve. Note that XDI won't give out the specific information unless you're a business tuner who also sells their product(s). Ask me how I know...
Alysium
California
so goosetune will take care of that or do I need someone or another shop to take care of what you mentioned if I go to the e85 route later on?
Stroked out
Florida
I just received my final revision for e50 today as well. Now on to my 93 octane tune. Does anybody have a write up on changing the hpfp? I've watched videos on utube and it doesn't seem bad. I'm new to the accessport, do you turn off the fuel pump while idling?
