Clunking sound in front end at low speeds when turning steering wheel
poser999
Dull clunk sound coming from front end that can be felt in steering wheel. Most noticeable when pulling into a parking spot and cranking the wheel half turn left or right. Its easily repeatable.
2013 with 58000 miles.
I'm about to crawl under it and take a look. Anything in particular that I should be looking for?
poser999
poser999
you may be right. i notice that i can make the creaking sound (not really a clunk) with the truck off and just cranking the steering wheel.
so is the coming loose from the frame that I can tighten or loose internals that need to be replaced?
Guardrail
Pa.
I had a similar problem. I would only feel the clunking when pulling into a parking lot or driveway that had a little bit of a lip higher than the road surface. I changed just about everything in the front end. Including the rack and pinion. Turned out it was the dust shield where the steering column comes through the firewall. There is a bearing in it. It was bone dry. I packed it with grease. Noise was gone.
Squad21
florida
Having a similar issue, was advised my ball joints are shot. This is turning into a money pit. Just serviced the shocks now the ball joints, I hope that's it at least for a while. I thought jeeps were bad.
